TITAN IRIDIUM - AMD LLANO SYSTEM!
11 Dec 2005
Cheshire
"Titan Iridium" AMD Llano A8 3850 2.90GHz DDR3 System @ £469.99 inc VAT
The "Titan Iridium" features a AMD Llano A8 3850 2.90GHz Processor, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system. With AMD's brand new APU technology you can run DX11 content straight out of the box. Enjoy the most powerful on-chip graphics to date with the "Titan Iridium".
Why Should You Buy This System?
- Includes the superb AMD Llano A8 3850 2.90GHz Processor Quad Core Processor
- Harness the power of AMD APU or choose from the latest DirectX 10 and 11 graphic cards
- 4GB of high performance gaming memory
- Precision built and cabled by Overclockers UK expert technicians
System Specification
- Case: BitFenix Shinobi Windowed Case - Black
- Power Supply: OCZ 600w StealthXStream II
- CPU: AMD Llano A8-3850 2.90GHz (Socket FM1)
- Cooler: Corsair H60 CPU Cooler
- Motherboard: AMD A75 Chipset (FM1) DDR3 Motherboard
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Hard Drives: 500GB HDD
- Graphics Card: Onboard APU or choice of the latest DirectX 10 and 11 graphic cards
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter (Black)
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
If your after the latest in AMD technology then this system is for you. Quad core technology and DDR3 performance at an excellent price point.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £469.99 inc VAT.
ORDER NOW
One suggestion, might be a good idea to add a memory upgrade option given the reviews show that 1866MHz RAM helps quite a bit with the onboard graphics?
I thought Rjk advise me not to bother with 1866MHz as sandybridge doesn't like high memory clock! Rjk advise me to get it down to 1600MHz instead.
This isnt Sandybridge so the advise is irrelevant. :rolleyes:
But with Llano, memory speed does make a difference especially with the GPU performance :)
wow 4ghz overclock!
and that is being conservative.
our sample and R&D testing saw these CPUs hitting well in excess of 4.5GHz
astounding for a relatively budget solution.
It certainly packs a punch, even at 4GHz!
Stick something like a Xonar DG in this and it's complete. :) A very balanced offering. Out of interest, what are the load temps like with this OC, when both CPU/GPU are fully loaded on the chip? I was also wondering if OCUK is getting any mITX FM1 boards in the near future?
Llano seems ideal for a punchy entertainment system where increased power draw over a Zacate alternative is not an issue. :)
Seriously ? No way !
It should be quite a beast, actually. Starting TDP of 100W helps, too, but you also have to consider that a part of that is the power required to drive the integrated GPU core, which is equivalent to a lower mid-end discrete card; hence the CPU module of this APU is open to some decent overclocking abuse with good cooling. :D
