Titan Quest, second play through need advice
23 Apr 2007
Cardiff-ish, Wales
Hi guys,
I'm waiting for Diablo 3 to come out and so dusted off Titan Quest as a stop gap. I completed it years ago with a level 35 Assassin and have recently bought Immortal Throne and thought it was about time that I'd give it a go. I notice that I can carry on with my level 35 for a second playthrough at Epic level and I can just walk through the bad guys when I start again. However, it looks like it'll take forever to level up at this stage. For example, I just completed the first quest and got 300XP. I need 275,000XP for my next level! I also noticed that I can teleport to all the locations right from the start. Am I supposed to go through each level sequentially, as in with my first playthrough or can I jump all over the place in any order?
Something's not right. Whenever I've imported a character into a higher difficulty it's the same progression as before, no skipping around. The map itself is all hidden again.
Are you sure you've gone into epic? It shouldn't really be a walk in the park, everything else is meant to have leveled up as well.
Aha ... the difficulty level had reverted to the first one, I just changed it to Epic and it's taking a few hits to kill anything now ... that seems more like it :)
Yeah, I reckon Epic is the most fun of the three since you actually have to think about your skills and build more.
Just about anything can get through Normal really, and Legendary is... well, a lot harder, but almost pointlessly so.
