"Titan Twinfire SLi" Intel Core 2 Duo E7400 2.80GHz DDR2 System only £599.99 inc VAT.
9 Nov 2003
Leeds
Combining the power of two Nvidia GeForce GTS 250 512MB graphics cards in SLI configuration you can be assured of smooth performance when the action heats up. Including the Intel Core 2 Duo E7400 2.80GHz processor multitasking is seamless even in the latest applications while the 4GB of Kingston HyperX memory allows for there to never be a pause in the action. Energy saving power supply and motherboard technology keep both temperatures and running costs down which increases overall system reliability.
Key Features
:- Dual graphics cards to provide the smoothest possible performance in games.
:- Dual Core CPU for seemless multi-tasking in the latest applications.
:- Energy saving components keeping running costs down.
:- Only the highest quality components ensuring the highest levels of reliability.
Key Components
:- Intel Core 2 Duo E7400 LGA775 'Wolfdale' 2.80GHz Processor
:- 4GB Kingston HyperX DDR2 800MHz RAM
:- 500GB Seagate 7200RPM Hard Drive
:- 2x Nvidia GeForce GTS 250 512MB GDDR3 PCI-Express Graphics Cards in SLI
Note - Specification not exactly what you are after? Drop our friendly Sales Team a call on 0870 443 0880, they will be more than happy to help you make your perfect system.
Note - All systems are built and installed on demand and usually ship within 48 hours of the order being placed. During exceptionally busy periods this time can increase by 48 hours. The system can be supplied assembled with or without your choice of installed operating system but is supplied without keyboard, mouse, speakers or monitor (all of which are available elsewhere in this on-line store).
£599.99 inc VAT
BUY NOW
