Titanfall controller ?
20 May 2014
Norfolk
Hiya, just a quick question.
I've had to send my XB1 pad back to Microsoft for a replacement as the left analog stick decided to break and become loose.
As it's going to take up to three weeks to receive a new one back..I decided to pick up one of the Titanfall controllers, my question is...does the pad come with the pre loaded update already built in ? Or do I still need to update it like I did before?
Any help appreciated. :)
I bought 2 of the Titanfall pads and updated both.. they seem to be a lot better than the standard ones.. The standard ones are just pathetic quality, I had 5-6 of them which were either faulty on first use or developed a fault within minutes.
Controller now updated, it does seem to be of a higher quality than the standard ones, fingers crossed the replacement day one pad won't be faulty or break so quickly.
I've had 2 Day One pads and a normal pad and had no problems with any of them.
Also got a Titanfall controller and agree on the build quality, it just seems that bit heavier and more solid.
