Titanfall to get Nvidia GameWorks features and 4K support on PCs
6 Oct 2007
North West
It has been revealed that Nvidia is collaborating with Respawn to "keep their multiplayer, first-person shooter at the cutting edge of image quality". The first person mech shooter will get a graphical shot in the arm by the companies artists and engineers working together to integrate Nvidia GameWorks features into the blockbuster title. Respawn and Nvidia will also update Titanfall to support 4K displays and make the most of SLI multi-GPU technology to give "a fantastic high-end PC experience".
The main GameWorks features that Nvidia says it is building into Titanfall include Temporal anti-aliasing (TXAA) and Horizon Based Ambient Occlusion+ (HBAO+). If you are not already aware of these technologies TXAA is an anti-aliasing technique which provides a high quality multi-sample smooth and clear image which also prevents unsightly crawling and flickering in motion. HBAO+ will create more lifelike non-uniform shadows in the Titanfall game to give a richer visual experience.
Titanfall sporting playable 4K graphics resolutions on the PC will only go further to demonstrate the PC vs console graphics quality divide. However, as usual with 4K, you will need to have a meaty PC in order to get good gaming framerates. With this in mind Nvidia and Respawn are working to get Nvidia's SLI multi-GPU technology up and running in Titanfall.
http://hexus.net/tech/news/graphics/67677-titanfall-get-nvidia-gameworks-features-4k-support-pcs/
Thanks,Gregster.
Even though its TN,the price is actually not bad TBH.
Its kind of futuristic looking.
Edit!!
You need this case:
http://www.overclockers.co.uk/LP/inwin-904.php
Ordered from that popular auction site.
Ahhh! I didn't want to do that, comes direct from SK doesn't it? (or have you found a UK based seller?)
I'll probably wait till its available from OCUK or the rainforest. Tempted by it though, but will have to change my card as the 670 just wont cut it, not with it's tiny 256bit bus...even though i do run lowered settings :p
Yer, from SK. Expected between 12th and 30th April, so not going to be here for awhile.
Will do Gee.
Will do Gee.
Worse than me for buying stuff :-)
But now back on triple monitors and dropped nvidia/3d for Eyefinity. After using triple monitors earlier, I just couldn't go back to single for some games. I did try 27 inch first, but, like yourself, found it just too much.
Current are dell u2414. Liking very much.
That Sammy does look lovely :-)
Awesome buy Greg. Surprisingly good price. That's how much I paid for my 1440p Asus panel less than a year ago :(
Would love to hear your feedback.
Will give a good in depth write up and give some benching graphs as well. It was the ROG Swift I wanted but that has been delayed till mid year, so the 4K 60Hz Sammy was too tempting to leave.
