Titanium Backup Pro Questions
18 Oct 2002
Carlisle, Cumbria.
Hi I've just got my Galaxy S3 and rooted it. I've paid for the Pro version of Titanium Backup Pro from the Market Place.
Q1: Where is the key file stored and what is the file name so I can copy it to my PC in case I need to reinstall it? Or can I just download it again fro free from the Market Place.
Q2:I've also created a Google drive account to backup files to. This is showing as enabled in Titanium Pro but nothing seems to be copied to Google Drive folder.
Q3:I want to try a few different launchers out so I presume if I create a profile for each launcher I can just restore the backup file of the launcher I'm happy with.
Cheers H@mmer.
Once you've purchased an app from the play store you can re-download it as many times as you like.
You can have multiple launchers installed at the same time, so just install all the ones your interested in, and then once you've decided on one uninstall the others.
Thanks for that, just need to sort the Google Drive or DropBox out now.
If the GoogleDrive is ticked green on the TB main screen then make sure you have set the options to use it as well. IIRC it doesn't automatically use GD, you have to set it up.
I have :
and
but still my Google Drive is empty.
In the Google drive settings I have told it to use a folder called Titanium Backup under the Remote Location menu and have synchronized everything under the Elements to synchronize tab.
What else do I have to do?
I don't think it does it automatically.
Once you have it setup, go to the "schedules" tab at the top and find "Sync to Google Drive" then just hit "Run"....
Looks like it's backing up to Google Drive now. That was the missing link.
Cheers Richie :)
