Tivo Disable Notification
15 Feb 2008
Hi,
Anyone know how to disable the pop-up alert which tells you a programme is about to start recording? on a Virgin Media Tivo box.
I have disbale the notification of recording, removed the programme suggestion and can not see any other options.
Only reason I ask is because it is causing a jump in other recordings at the same time, this sometimes causing audio sync problems.
cheers.
