Does anyone know where i can get decent replacement side grills for my tj07.
there is nothing wrong with the ones i have other than they are too restrictive and cause a lot of noise with the fans turned up.
i have a bottom mounted 480mm rad with 4 gt's sucking into the case and with the side panel off they are pretty quiet and with the side panel on it makes too much noise.
i found some quite nice looking hex mesh replacements from a european site i won't mention, but they were made of matt black plexi and i'd rather have metal grills. also couldn't find any decent pics of them fitted to a case so not sure how nice they look.
