TJ08 - Can you fit a double rad in the front?
  • Thread starter Thread starter HeX
  • Start date Start date
HeX
HeX
20 Jun 2004
Huddersfield, UK
As title really, if one were to remove the HDD cage could you mount a double rad at the front?
If you look at this pic:
Click Me
It does look like you could.
Can't decide between the SG03 or the TJ08, i'd prefer the SG03, but the TJ08 looks a far better candidate for half decent cooling due to the more traditional PSU placement.
Looks like it would be a little tight.
Agree about the layout with the PSU there... much nicer.
You considered 2x 120.1's instead? With the barbs down the side there would be room.
Crude mock up using the 120mm fan from the rear rotated and mirrored - will be quite tight:
gt
Yeah it does look like it might be a bit of a squeeze...
Considered 2 x 120.1's but it looks like the rear one would interfere with the PCI-E slot...
(Nice mockup BTW :D)
is there room for the connections for the tubbing in / out of the radiators on the front?
Looks like the one at the back would be more feesable - if you were to raise it a little.
It's not going to interfere with the PCI-E as the PCI slot lines up with the slot on the board and the fan isn't covering that. It would just be very close :D
Just looking at this pic (HERE), if you mounted the rear rad with the barbs at the top, it prolly would just scrape in without getting in the way of the PCI-E card... same with the front rad, as long as its mounted upside down it should fit in fine... hmmmm
I wouldn't need to loose the HDD cage then...
Something like the XSPC RS120:
http://www.xspc.biz/rs120black.php
I've been reading that you are right gt, you can mount 2 x 120.1 sideways at the front
Also if I went for something like the P5E-VM the PCI-E graphics slot is actually one slot lower (than the board pictured fitted to the case)...
Now to look at pumps :D
Just discovered that the Coolermaster 340 Elite is the exact same case as the TJ08 and 1/3rd the price... whats that all about! :eek:
really, you sure? I can see they have the same arrangement, but the silverstone is DEFINATELY tons sexier!
Yup exact same case, only the facia is different.
Whereas the 340 is ~£22, the TJ08 is ~£58...
I agree the TJ08 front looks far nicer, but £35 for a pretty front is a bit much!
