TJ08 water cooled
1 Jan 2012
Scottish Borders - UK
Thought you may appreciate me recent build
I5 2500K, GTX670, ASUS Maximus Gene V.
Going to mount a RX240 on the rear seeing as I have it sitting doing nothing. :)
Any idea how I can get rid of the tiny bubbles in the res??
they're still there - not as bad as that though.
The D5 is only on speed 1 - would running it on 5 for a while do the job?
Try the pump around 3, though you'll find all the smaller bubbles will disappear over time so I wouldn't worry about it too much.
You going to mod the rear of the case for tubing pass throughs or fit a PCI bracket/bulkhead?
Yeah, I'll mod the rear. There's a decent meshed section to the side of the PCI brackets. I'll either cut it out completely or cut out two holes for hoses/grommets.
