TM warthog throttle
1 Dec 2006
Hi all
I recently bought and installed all my old hardware into a new case and until last night had not got round to plugging in my hotas
For some reason the throttle is no longer being recognised when it is plugged in and just comes up in device manager as a default icon with a yellow triangle
I have done a quick google but i am at work and most of the sites that show a responce to this problem are blocked. The only thing I could find out is that a firmware update might help but as its not a recognised device its not on the firmware updater supplied by CH
Has anyone had a similar problem and can give me some advice before I get home later and check out the forums that are blocked at work?
Ta
