To AMD card owners
26 Jan 2010
Sorry guys but just created this thread as Id like to know what settings you have on you CCC control panel, and i you would reccomend me changing my current settings as below:
guys, what settings do you have on your CCC panel if you gave an amd 7970 card?
ive got mine on default settings :
Anti aliasing mode: Use application settings
Anti Aliasing samples: Use application settings
Filter: Standard
Anti Aliasing method: Multisampling
Morphological filtering: Off
Texture Filtering
Antistropic Filtering Mode: Use application settings
Antistropic Filtering Level: Use application settings
Texture filtering quality: standard (should I change this for better eye candy?)
Surface Format Optimisation: On
Framerate control
Wait for vertical refresh: Off unless application specifies
Open GL triple buffering: Off (should be off right?)
Tessalation mode: AMD Optimised (Should I change this?)
Maximum Tessalation Level: AMD Optimised
It varies on the game, but this is what I have at the mo :
Depends on the game.
well i have the latest PC games watchdogs, crysis3, wargame red dragon,BF4 and theif ect, they are all demanding games as I run off a 27inch dell 2560x1440 monitor, i never go below the native resolution, when I do for instance 1900x1200 or 1900x1080 the games look so blurry to me....
I was thinking some people may have specific setting for better results, thought if anyone posted their settings i could try it out to see if there is a diffrence....
I have ecxactly the same settings as ypu apart from the texture settings, u have yours on high quality....
To be honest I have increased the texture on my settings before and I didnt see a difference, only in 1 game i think I had some stuttering, so I put it back to default settings.
