To buy a P180 or not
12 Jan 2006
Pondering whether to buy a P180 (http://www.overclockers.co.uk/acatalog/Antec_Cases.html) or not, i have been hearing very good things about it. But my current build is costing £1047.75 inc Vat, seeing as i was only planning £1000 i dont really want to go much higher.
My current case is a :
http://www.chieftec.com/products/Workcolor/Dragon.htm
It is a very nice case, pleanty of room and all the necesary things click out easily with space for lots of fans.
In short is the P180 really worth spending £80 more
tnx in advance
I've got a Chieftech Dragon at the moment and I doubt there would be much benefit in changing to an Antec P180 other than it has a nice mirrored finish and maybe a little better design in terms of airflow. The Dragon is huge and cool though so I can't see any real need to change.
You could always stick with what you have just now and if you have any problems get a P180 later.
I have one... Good case.
BUT if your current dragon is good and your happy with it why change?
You can always change case at a later date...
Save yer cash for now.
Sam C
i wouldnt bother. if you like your current case then dont bother upgrading that just because you have everything else. :)
my jeanteach phong cost £35 and its a bit small but looks nice and does me. i wouldnt spend more than that on a case now - ive been spoilt. :o
