To deathadder users : cursor problem
12 Oct 2005
Noticed a problem with my deathadder, as it was putting my aim off in games, which was annoying the hell out of me... anyway the ticket I sent to razorzone:
OS: XP Pro SP2
Driver 1.06
Firmware 1.21
When moving the mouse up and down in a straight line (using a hard surface either side of the mouse to keep it straight) the mouse cursor will start moving to the left (half life one engine) or to the right (windows and half life 2 engine); hence causing aiming problems.
Since making that ticket, I've tried the new drivers (1.07) and no luck. Have any of you lot got the same problem aswell? Trying to see if its a common thing or just my mouse.
I am using vista and havent experienced the problem, if its the mouse thats the problem then hopefully you can RMA it.
