I bought a Dtek FusionV2 from a forum member and it came with a quad nozzle thingy;
http://www.overclockers.co.uk/showproduct.php?prodid=WC-005-DT&groupid=701&catid=193&subcat=1044
So the question is, should I go with the quad nozzle (as I have a Q9550) or the standard one? I've read that the quad nozzle doesn't make that much difference and that they can reduce the flow and increase the temps of other components in a multi block loop. I've got my GPU in the loop too (full build details in the link in my sig).
It seems to be tricky to find a direct comparison. There was a review on XSf but the images have gone. I figured that there's probably some peeps here with experience of this.
Thanks
Thanks
