Just wondering if I should stick with pal framerates, or go 30/60 fps?
I realise that in certain situations using 30/60 fps can cause flicker in countries where electricity runs at 50hz, but this can often be compensated for by setting shutter speed normally.
And as it's likely most of what I do would be web shared and viewed on monitors, and as oretty much all tv's these days perfectly capable of 50/60hz display, is there really any point to sicking to 25fps?
Better going for the higher frame rates?
