I've done a little bit of googling on this but failed to find definitive answers.
Using Akasa venom with 1 * push fan at the moment. Will push/pull provide better cooling?
Or is push-pull fans advantage mostly negated by added turbulence? I'm assuming it would be impossible to synchronise both fans to eliminate turbulence. Would added turbulence create more noise? Should fans be a matched pair?
My Asus p8p67 has only 1 * 4 pin cpu fan header. If I were to try push-pull, how would I connect it to a single 4 pin cpu header? Should I just get a 2nd cpu fan with 3 pins and connect to the 3 pin header next to the existing 4 pin cpu header on the Asus p8p67? Thus using one 3 pin and 1 4 pin fan.
Thanks folks.
Thanks folks.
