Go play UT3 with it, you will get RSI!
Atari Jaguar controller for the win!
The improved thumb sticks are noticeable even just in the internet browser. With the regular sixaxis, the cursor doesn't move unless you move the thumbstick half way. But with the DS3, even a twitch will move it.
no different here, tried both taking turns, still moves same difference before it moves the cursor
I think I might have this new Sixaxis, I can't see through the plastic of mine at all!
Need to get the DS3 eventually though.
new as in last of the 60gig with the see through plastic on the controller, i see no difference between the two except for rumble and better weight and build quailty.
The 3DO, CDi and Jaguar are the reasons I said "Major"You never had a 3do did you?![]()
.Not really bothered about rumble but have bought another standard controller and noticed that the new pad is slightly clearthrough compared to my default pad that came with the 40gb console which is solid black. I think it's what's know as smokey black finish.
Anyway, wouldn't the rumble drain the battery much quicker?
personally i see no difference except for rumble and build, apart from thats its identical, are you lot sure its just not shiny new toy syndrome and thinking its better?
The sticks are no different, the triggers are no different, the buttons are no different.
