to SLI or not..
12 Dec 2009
Gloucester, UK
:confused:
Well i have been reading thread after thread and looking around lots of websites. I was thinking about purchasing - http://www.overclockers.co.uk/showproduct.php?prodid=GX-128-PC - Which i have no doubt is one heck of a power beast. However.. Do i really benefit from spending so much with regards to gaming? Or am i just spending lots on a card thats got software issues.. Would i be better getting two cheaper cards and getting the same power output?
Yes im fairly noobie at this stuff, but i know you guys generally know your stuff so guide me here!
:eek:
SLI is the nVidia term on ATI cards its called crossfire for multi GPU.
If your playing at resolutions over 1920x and more than 8x AA with the latest games and don't plan on upgrading for awhile after then it might be worth it... if your playing upto 1920x and under 8x AA then you'd be perfectly happy with a 5870 or even 5850.
really the 5970 is 2 5870 chips just underclocked so really you could just get a 5850 for now and when there cheaper buy a 2nd.
just my 2 cents
:confused:
:eek:
You are always better of with the single fastest card you can get.
That way your not relaying on your motherboard dual GPU performance, a bunch of monkeys writing software with bias. And you don't need to pay for a sli licensed PSU.
Don't listen to the multi GPU haters.
I don't, in fact I'm currently running two GTX 260 216s in my pc, but only because I'm a bit of a hardware whore :D
I was originally going to sli my 280 but these 260s came up cheap in mm so I went for them.
I do think it's good advice though for the majority of people who probably don't upgrade as often as myself :o
Get the most powerfull single gpu card you can afford at the time, and then you can always sli or crossfire it at a later date.
You'll notice I didn't quote all of jiggers post ;)
Got my hands on a couple of gigabyte 260GTX Super Overclocked... running 1500 shaders out the box and will do atleast 1550 - haven't tested above that yet... performance is nothing to sniff at.
Yes I think I remember you talking about these in another thread. I've actually read the legitreview on those cards, they do look pretty tasty.
Dont listen to Rroff he just has a boner for all things SLI.
Dual Card setups are still full of fail, anyone that says otherwise is very lucky or plain wrong.
Lol when were SLi/crossfire crap in the last year or two?
When i did it i saw a helluva lot more performance in a lot of games..
Although if it was me, i'd get a 5870, and get another later next year for cheap.
lol.
Why are dual card setups full of fail?
They offer from 50% to 90% boost (depending to resolution) and don't cause any problems.
A few years ago when dual card setup were uncommon, there were problems yes, but now the drivers/cards have matured enough not to have those problems anymore.
jigger is a troll. I've engaged with him in discussions before about the subject and asked him if he has ever actually ever owned a multi-gpu setup, or even actually looked at any reviews, and he never answers.
Multi-GPU is, for the most part, quite good these days but it is still better to buy a single high-end card if you can.
:rolleyes: What a ludicrous comment, unfortunately very typical of a very ill-informed and very vocal minority on these forums.
