To stick, upgrade or migrate...
16 Aug 2003
I have been with F2S about 4-5 years now, I have never had a problem even though I believe they have been bought out by Pipex which seem to get a few bad reviews for traffic shaping etc. I still have an account that you cannot sign up for anymore which is 1MB unlimited. I have now seen via the BT website that my line should give me up a 'likely' speed of up to 4MB.
So question is..... Is it worth sticking with what I have got, upgrading to an up to 8MB account but has a 50GB limit or migrate to another provider.
This is my current speed test.
P.S. Cable is not an option as it is not available...
Well it depends if your happy with your 1mb package mate. If the line can handle more speed, perhaps try an upgrade. Or migrate. Most migrations are now free so no activation is needed. You could probably get the faster speed for the same price you're paying now, or just a bit more, so it may be worthwhile upgrading. :)
If you can upgrade with out being put on another 12month contract you might as well, especially if it is free. If you just use your connection for internet and happy than there is no point fixing what isn't broke.
