To upgrade CPU cooler or not?
8 Mar 2011
My current cooler is the beast known as the Thermalright HR-02 Macho. Its a grand cooler but even before I got the cooler I always had an eye on the Corsair Hydro Series H100 extreme performance liquid CPU cooler.
Im just wondering is there any point upgradin to the H100. Will there be a notable difference in noise(fans) and temperature?
My motherboard is the ASRock Z77 Extreme4, Intel Core i5-2500K LGA1155 and my case is the C70 vengeance
No there is no reason to change coolers
Yes, H100 is much louder and only slightly cooler. If you run same fans on both coolers the H100 is 1-1.5c cooler. Add to that the pump and fan speed control issues H100 has so for me it's would be a no-brainer.... live with the beast you know instead of the beast you don't :D
Cooling:
http://www.xbitlabs.com/articles/coolers/display/thermalright-hr02_5.html#sect0
Nosie:
whisper in library 30.0dBA
HR-02 full speed (1300rpm) 39.5dBA
H100 minimum speed 40.9dBA
H100 full speed (2600rpm) 53.2dBA
normal conversation 60dBA
If I had HR-02 and wanted more cooling without sacrificing silent operation the Thermalright Silver Arrow SB-E Extreme with it's TY-143 fans (800-2500rpm) would be my choice... and can be had cheap with a little shopping. I have compared the TY-140 and TY-143 fans on my Phanteks PH-TC14PE. From idle to 1300rpm they sound the same... But batten down the hatchs when you crank them on up to 2500rpm!! 1300rpm = 74cfm; 2500rpm = 130cfm :eek: IMHO they are quieter and cool better than stock Phanteks fans.
Fan speeds TY-140 & TY-143 on same PWM signal
TY-140 635 800 860 . 915 . 975 1010 1080 1110 1150 1215 1220 1270 1305 1330rpm
TY-143 605 800 950 1110, 1260 1400 1550 1700 1850 2000 2150 2300 2400 2500rpm
