Thank for the advices guys, there will be a build log for this setup later, but atm still try to sort out the bits for the custom watercooling(yes going with plan B instead of A), here is my new list of parts for the setup, what do you guys think?
EK Supreme HF Nickel CPU block (ordered)
EK FC5870 V2 Nickel GPU block x2 (ordered)
Thermochill PA140.3 triple Rad & XSPC RX240 120mm Radiator - Black or will 1x PA120.4 able to cool both CPU and X-fire GPUs?
for pump will this be ok? XSPC 5.25" Dual Drive Bay Reservoir for One Laing DDC Pump or do i need this instead? XSPC 5.25" Dual Drive Bay Reservoir for Dual Loop & Two Laing DDC Pumps.
just need some advices on the pump/reservoir and the Rad then i can order those as well...thank guys
