With this wonderful weather we're having...I have a bit of rust coming up on my chain. It's brand new so it's showing up nice n' brown.
I usually use a dry lube (Wurth) but it doesn't keep the rust away.
I've heard a lot of people use AFC-50 once in a while to lube the chain, but considering how much I'd use, it gets pretty expensive over time.
The next option is WD40. Some people swear by it, some people use it now and again to keep rust away, and some say it actually damages the chain because it's a fast moving metal on metal component, and apparently WD is useless when it comes to that purpose.
So what's you're opinion? I'm tempted to use WD as part of the cleaning process tomorrow, but the last thing I want to do is any serious damage to the chain. And if you do use WD, do you use other lubes on top of that such as a dry lube?
Cheers.
Cheers.
