Caporegime
- 1 Mar 2008
MOT on Thursday, list for sale on Friday. That was the plan for my 02 Saxo.
That is until last night...
Heading to football, I'm doing 60 down the road and a car infront of me is turning off so I slow down. As he turns in, I put my foot on the accelerator again and there's some loss of power and a lot of noise. Pull in and check under the bonnet to see the Cat Converter sensor cable dangling underneath the car. It has broken free, leaving a hole.
Took it to get looked at today and was given two options. £150 for a new converter including fitting, or he would attempt to weld it to put it through the MOT for £30 but he said it won't be a good job and it could result in cutting out.
Which would you go for? Would you be happy finding it has been welded after buying the car? I certainly wouldn't.
EDIT: Not mine, but an example.
It has broken away around the red ring.
