Basically im looking for a monitor (will be buying this week
) and just wanted some opinions as to whether i should go wide screen or not? what are the pros/cons? i mainly play UT2004, Q4, Doom3, Footy manager 2007, and for uni I use 3dsmax, Adobe after effects and Adobe Encore DVD, what would be my best approach? I do watch movies on here but only sometimes. My main problems are really will my gfx card be able to handle the Monitor well enough, my spec is in my sig
Ta In Advance
Kiz
) and just wanted some opinions as to whether i should go wide screen or not? what are the pros/cons? i mainly play UT2004, Q4, Doom3, Footy manager 2007, and for uni I use 3dsmax, Adobe after effects and Adobe Encore DVD, what would be my best approach? I do watch movies on here but only sometimes. My main problems are really will my gfx card be able to handle the Monitor well enough, my spec is in my sigTa In Advance
Kiz
, i really really want a 22"WS but i've seen how it disrupts counterstrike 1.6 which i'm a hardcore gamer of and still play competitively and i'm also concerned that it won't be able to keep up (refresh wise)!
