Today Only Deals! Snap a bargain.
NZXT Phantom 410 Enthusiast Midi Tower Case - Black @ £71.99 inc VAT
NZXT introduces the descendant of the revolutionary Phantom, the Phantom 410. The beautiful and sleek Phantom design set the trend of all cases and idealized optimal expansion and cooling. In comparison to its predecessor, the Phantom 410 delivers more value for every penny spent and possesses an acrylic window that allows gamers to admire the power of their rig.
The Phantom 410 features an innovative right mounted HDD rails, a solution for easy hard drive replacement. This mid tower comes equipped with a dual radiator water cooling solution with a clearance of 30mm, an interior pivot 120mm/140mm fan slot, the capability of installing up to 8 fans, and a single 30W fan control. The Phantom comes with up-to-date internal 2x USB 3.0 headers that directly connect to the motherboard. Be the envy of all PC gamers - the Phantom 410 is bringing sexy back.
- Dimensions(W x H x D): 215 x 516 X 532 mm
- VGA Clearance Maximum: 305mm (w/o fan), 280mm (installed), 230mm (full pivot)
- Front Cooling: 2x120mm or 1 X 140mm (1x120mm included)
- Rear Cooling: 1 X 120mm (included)
- Side Cooling: 1 x 120mm or 1 x 140mm
- Top Cooling 2 X 120/140mm (1 x 140mm included)
- Drive Bays: 3 x external 5.25" / 6 x internal 3.5"
- Screwless Rail Design
- Expansion Slots: 7
Only £71.99 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Analog Gaming Headset @ £55.20 inc VAT
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels.
- Real 5.1 Surround sound with speakers aligned at a 12° angle
- Microphone with mute LED fully rotatable and completely removable
- Tip’N’Control desktop remote for central management of all volume functions
- Dual sound-profile with movie and game settings
- Solid aluminium hinges enabling heavy duty use
- Hand-sewn comfortable earcups featuring external noise cancelling
- Adjustable vibration unit for a realistic gaming experience
- Headband with three pads for equal weight distribution
- Easy to carry folding and compact design
Only £55.20 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
