**TODAY ONLY! 01/05/2014** Intel CPU goodness *dun dun dun dun*
OcUK Staff
4 Feb 2013
So I'm hoping you all read *dun dun dun dun* as the little Intel sound from the adverts - if not, SHAME ON YOU!
Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM @ £149.99 inc VAT
Intel's 4th gen processor codename: Haswell offers superior performance over the previous generation Ivybridge by up to 10% clock for clock. This astounding performance boost results in performance improvements in multi-tasking, encoding, gaming and multithreaded applications. Intel's 4th generation processor has improved PCI-Lane 3.0 bandwidth which helps further boost performance of latest generation 3 graphics cards for the ultimate gaming experience.
For overclocking enthusiasts, Intel's 4th gen CPU has improved memory overclocking support, with up to and beyond 3000MHz possible with the very best memory kits. Memory bandwidth is critically important to Haswell compared to previous generations. High frequency memory performance significantly improves encoding, gaming and benchmarking tasks.
The biggest leap in Intel's Haswell processor is the onboard graphics which is now up to 2.6x faster than previous HD4600 found in the Ivybridge CPU. What this means is these latest processors can actually play the latest games in HD with low/medium settings applied. Of course if you want to experience True HD gaming at maximum details then a dedicated graphics card is still a must.
There are two words in your vocabulary that should never meet—Game and Over. You love playing, and you love winning, so you demand unmatched performance, the ability to customize your rig, and features that put you in control of the action. With Intel® technology, you step into a heart-pounding experience. Pick up your weapon, challenge your friends, and experience gaming at its best—because the only thing more amazing than Intel® technology is what you’ll do with it.
As a creative force and a professional, you must continually balance your vision with the deadlines of the real world. Intel® technology helps you keep up with your creativity with unmatched and customizable performance, and features that give you full control to optimize your workflow and maximize your productivity. So keep imagining, keep creating, and take your inspiration to the limit—because the only thing more amazing than Intel® technology is what you’ll do with it.
Features:-
- Upto 10% performance increase over Ivybridge on CPU performance
- Upto 2.6x performance increase on 3D Graphics (onboard GPU) with DX11.1 Support & OCL1.2
- Better OC Flexibility with memory timings and speeds
- 4k and Collage Display support
- Intel Password Guard for SBA and improved protection against data theft
Specification:-
- Lithography Process: 22 nm
- Cores: 4
- Threads: 4
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated HD 4600 Graphics
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 1600/1866/2133/2400/2666+ MHz
- Socket: LGA1150
- Memory compatibility: All DDR3 1333MHz and above is compatible
- PSU compatibility: Check out our range of Haswell compatible PSU's - http://www.overclockers.co.uk/productlist.php?groupid=701&catid=123&subid=2597
- 1yr Warranty
Only £149.99 inc VAT.
ORDER NOW
_____
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM @ £219.95 inc VAT
Features:-
Specification:-
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- Cache: 8 MB shared L3
- Socket: LGA1150
- 1yr Warranty
Only £219.95 inc VAT.
ORDER NOW
what happens to the oem ones that don't make the grade ?
there was posts on here somewhere.
sticky should be made.
I bought an OEM 4670K very recently from OCUK.
It was an average clocker, but it was obvious it had NOT been used before. (Flawless on the IHS, no marks on the sides)
