**Today Only 01/08/2013** Lian Li PC-A05FNB Aluminium Midi Tower Case & MSI HD 7950 Twin Frozr III B
22 Aug 2010
Today's Deals!
Lian Li PC-A05FNB Aluminium Midi Tower Case - Black @ £61.61 inc VAT
With its mid-tower form factor, the PC-A05FN features a 120mm intake fan - positioned at the top of the rear panel - and a 120mm exhaust fan, which finds itself located on the front panel, in front of the HDD bay. The PSU bay is also located at the front of the chassis, and for additional cooling, there's accommodation for a 140mm fan along the top panel, and venting too. As usual, Lian Li also includes two rubber-lined holes on the rear panel, allowing for flexibility with the installation of liquid cooling solutions.
The PC-A05FN provides three 3.5in and two 2.5in bays internally, plus a single 3.5in and two external 5.25in bays. Graphics cards up to 280mm in length are supported.
- Dimensions: (W) 210mm x (H) 385mm x (D) 500mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay (External): 2
- 3.5" drive bay (External): 1
- HDD bay: 3.5” HDD x 3 / 2.5” HDD x 2
- Expansion Slots: 8
- Motherboard: ATX / Micro-ATX / Mini-ITX
- System Fan (Front): 120mm Fan x 1
- System Fan (Top): 140mm Fan Hole x 1 ( Fan not included )
- System Fan (Rear): 120mm Fan x 1
- I/O Ports: USB 3.0 x 1 / USB 2.0 x 1 / HD Audio
- Maximum Video Card Size: 280mm
Only £61.61 inc VAT.
ORDER NOW
MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** @ £239.99 inc VAT
Introduction
Leading global mainboard and graphics card maker MSI today announces the release of the R7950 Twin Frozr III/OC graphics card. This graphics card features the latest AMD 7950 chipset with 1792 stream processors and 3072MB of 384-bit GDDR5 high-speed graphics memory. The greatly improved overclocking potential and stability increases overclocking performance up to 37.5%! The highly acclaimed Twin Frozr III thermal design with 8cm Propeller Blades fan setup for 20% more air flow and 8mm SuperPipe technology is used for cooling. Fan noise of just 30dB at full load provides gamers the most silence user experience, while MSI Military Class II components are used to give the highest quality and stability. For gamers seeking overclocking potential, cooling and stability, the R7950 Twin Frozr III/OC graphics card offers the perfect solution! This Boost Edition has an impressive base clock of 880MHz, but even more impressive is the Boost clock of 960MHz out the box.
Only £239.99 inc VAT.
ORDER NOW
