**Today Only 01/09/2011** MSI GeForce GTX 580 Lightning 1536MB & Crucial RealSSD M4 64GB
22 Aug 2010
Today we have limited units and price drops which you will not want to miss out on. Take a look at these two top pieces of kit which will improve your gaming experience!
MSI GeForce GTX 580 Lightning 1536MB GDDR5 PCI-Express Graphics Card @ £399.98 inc VAT
These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled N580GTX Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records!
Key Features<
Industry-leading Power4 Architecture for Overclocking Reliability
Inheriting the impressive Power4 architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there.
Twin Frozr III and Propeller Blade Technology Takes Cooling to the Next Level
The all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 21°C lower than the reference board when the N580GTX Lightning are operating under full loads. Fan noise is also 5dB lower in addition to having much higher overclocking potential.
Overclocking Potential Unleashed with GPU/Memory/PLL Triple Overvoltage
The MSI N580GTX Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of N580GTX Lightning is 30% higher than the reference board and offers enthusiasts ultimate performance.
King of Extreme Overclocking
For hardware enthusiasts, the MSI N580GTX Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios and XtremeCool switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the N580GTX Lightning the ultimate graphic cards for extreme overclocking
Carefully Selected Materials
The MSI N580GTX Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
Specifications
CUDA Cores - 512 Units
Core Clock - 832 MHz
Shader Clock - 1747 MHz
Memory Clock - 4200 MHz
Memory Size - 1536MB GDDR5
Memory Bus - 384 bits
Output - DisplayPort / HDMI / DVI x 2
TDP - 260 W
Card Dimension - 305x127x45mm
DirectX 11 - Y
CUDA - Y
SLI - Y, 3-Way
PhysX - Y
PureVideo HD - Y
HDCP - Y
- World’s first 16 phase PWM on GTX 580.
- Independent, dedicated Memory power support.
- Copper MOS with 2x high current capacity
- Proadlizer x 4 to optimized power supply.
- Twin Frozr III Thermal Design with 21C cooler & 5.5 dB quieter.
- Propeller Blade technology for 20% more airflow.
- Dual 9cm fans with dual 8mm SuperPipes for best heat dissipation.
- Form-in-one heatsink covers memory and modules to dissipate heat efficiency.
- World’s first GTX 580 graphics card supporting voltage adjustment of GPU/Memory/PLL.
- Military Class II Components for longer product lifespan.
- LPL (Lightning Power Layer) for the stable power supply.
- Usage of the Micro/DIP switches on rear of card voids warranty - For extreme/expert overclockers ONLY!
Now with Three Year Warranty
Only £399.98 inc VAT.
ORDER NOW
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive @ £74.99 inc VAT
Continuing the tradition of our award-winning solid-state drives, the Crucial m4 offers mobile and desktop users scorching-fast read and write speeds. Low power, lightweight, and durable, it empowers high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management, and the SATA 6Gb/s interface. Together, that technology dramatically improves data transfers for bandwidth-demanding applications.
Our products are built on decades of design and manufacturing expertise. It is our expertise in NAND technology that enables us to optimize the performance and endurance necessary to build quality solid-state storage devices.
- Sequential Read (up to): 415MB/sec (SATA 6Gb/s)
- Sequential Write (up to): 95MB/sec (SATA 6Gb/s)
- Random 4k Read: 40,000 IOPS
- Random 4k Write: 20,000 IOPS
- PCMark Vantage: 55K HDD Test Score
- Interface: SATA 6Gbps / Backwards Compatible 3Gbps
- Native TRIM support
- Seek Time: .1ms
- Slim 2.5" Design
- 100.5 x 69.85 x 9.5mm
- Lightweight: 75g
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -40°C ~ 85°C
- Low Power Consumption: 150 mW in operation, .65 mW in standby
- Shock Resistant up to 1500G
- RAID Support
- MTBF: 1.2 million hours
- Limited 3-Year Warranty
** FIRMWARE UPDATE 0009 - Increased speeds up to 540MB/s **
Only £74.99 inc VAT.
ORDER NOW
