**TODAY ONLY! 01/09/2014** Asus GeForce GTX 770 DirectCU OC 2GB Graphics Card and AOC Q2770PQU 27" M
OcUK Staff
12 Apr 2008
OcUK HQ
Asus GeForce GTX 770 DirectCU OC 2048MB GDDR5 PCI-Express Graphics Card @ £217.99 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1058MHz (GK104)
- Core Boost Clock: 1110MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2220MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £217.99 inc VAT.
ORDER NOW
AOC Q2770PQU 27" Widescreen LED Monitor - Black @ £319.99 inc VAT
Experience a new level of sharpness with this large 68.6 cm (27”) monitor. The q2770Pqu utilises a state-of-the-art Super PLS panel with the stunning WQHD resolution of 2560 x 1440 pixels. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, plus speakers as well as a USB hub integrated into the bezel, this energy-efficient display offers you a multitude of applications, delivering exceptionally crisp and vivid images for even the highest demands. Benefit further from full ergonomic flexibility with 130 mm height adjustment, tilt, swivel and pivot (= portrait mode rotation) function. The q2770Pqu comes in a classy black texturised design and features eco-friendly LED-backlights .It fulfils sustainability certificates such as Energy Star 6.0, TCO 6.0 and EPEAT Gold. Let the q2770Pqu impress you today!
Specification:-
- Monitor Size: 27"
- Visible Screen Size: 68,6 cm
- Screen Format: 16:9
- Brightness: 300 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1 (DCR)
- Contrast Ratio Typical: 1.000:1
- Pixel / Dot / Pitch: 0.311 (H) x 0.311 (V) mm
- Display Area: 597.89 (H) x 336.31 (V) mm
- Viewing Angle: 178°/178° (CR=10)
- Response Time: 5 ms GtG
- Maximum Resolution: 2560x1440@60Hz
- Recommend Resolution: 2560x1440@60Hz
- Colors: 16.7 M
- Connectivity: 1x VGA, 1x DVI-D, 1x Display Port Input, 1x HDMI
- Dimensions (WxHxD): 642 x 558 (+130) x 245
- Weight: 7.5 kg
- Warranty: 3 Years
Only £319.99 inc VAT.
ORDER NOW
The AOC is a great screen, bought one a few months ago, would like to see it drop a little further as i want another two;)
