**TODAY ONLY! 01/10/2014** Superflower Leadex Gold 650W & Hazro HZ30WiG V2.0 30" Monitor
OcUK Staff
4 Feb 2013
SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - Black @ £67.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Speciication:-
- Type: ATX
- Maximum Power: 650W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@22A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £67.99 inc VAT.
ORDER NOW
_____
Hazro HZ30WiG V2.0 10-Bit 30" LED Widescreen Professional Monitor - Black Metal Casing **CLEARANCE** @ £399.95 inc VAT
**CLEARANCE SALE, BRAND NEW WITH 1yr WARRANTY**
The Hazro HZ30WiG is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. AH-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30WiG performs with consistency and clarity to optimise your visual experience. The Hazro HZ30WiG recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30WiG collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30WiG, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30WiG offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30WiG is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Specification:-
- Panel Technology: AH In Plane Switching - 3H Anti Glare Hard Coating
- Size: 30“ / 75.6 cm (WQXGA)
- Aspect Ratio: 16:10
- Viewable Image: 641.3 mm x 400.8 mm
- Pixel Pitch: 0.251 mm
- Luminance (typ.): 350 cd/m²
- Contrast (typ.): 1000:1 / 2000000:1 (dynamic)
- Viewing Angle: 178° horizontal / 178° vertical
- Response Time (typ.): 6 ms (grey-to-grey)
- Colors / Gamut: 1.074 billion (10 bit per color)
- 107% Adobe RGB, 120% NTSC (CIE 1931) 100% ISOcoated v2 (UDACT), 98% ECI-RGB
- Connectivity: 1 x DVI-D, 1 x DisplayPort (10 bit), 1 x HDMI, 1 x RGB (VGA)
- Power: DC 4pin 120W (24V)
- Horizontal Frequency: 31.5 - 98.7 kHz
- Frame Rate: 30 - 85 Hz
- Optimal Resolution: 2560 x 1600 Pixels @ 60 Hz
- Mounting Options: VESA 100x100 (M4 Thread) / Stand removable
- Warranty: 1 Years Swap Out
- Assembled in: United Kingdom
Only £399.95 inc VAT.
ORDER NOW
Just ordered the PSU. Was waiting for the EVGA Supernova G2 750w to come back into stock but I don't need 750, probably not even 650 according to a PSU calculator. £20.00 less makes easy sense.
I can finally retire my 8 year old Corsair TX750. :D
