Prolimatech 48 CPU Cooler - 92mm @ £14.99 inc VAT
The Basic 48 features three high quality heat pipes and one PWM 92mm Hydro-Dynamic bearing fan. Its small size is well suited for small cases. Intel and AMD compatible.
The Basic Series offers competitive solid performance at a budget level price! They are designed to be affordable while still maintaining the reliable quality you've come to expect from us. They are an excellent option for replacing stock coolers in any system, for improved cooling, quieter operation, and even overclocking! Check out the 5 different models to find the perfect cooler for your hardware, be it small media centers to massive hungry processors!
- Material: Nickel plated copper (heat pipes), Copper (base plate), aluminum (blades, base plate)
- Heatpipes: 3x Ø 6 mm
- Fan: 1x 92 mm
- Connector: 4-pin PWM
- Speed: 1500-2000 r / min (+ / - 10%)
- Dimensions: 100 x 125 x 55 mm (W x H x D)
- Weight: about 309 g
Only £14.99 inc VAT.
ORDER NOW
______
Coolgate CG420 420mm Radiator - Black @ £64.80 inc VAT
The Coolgate Tripple140mm radiator is a combination of all the best designs making it versatile and a performance beast. Designed with triple parallel rows minimizes water resistance the Coolgate series achieves optimal cooling performance.
Featuring inner tubes made of 90% copper this series is made for high end performance. Set up options are available with the dual in and out G1/4 threaded ports along with the fill port on the opposite side making this the most flexible radiator available. Fan silencers are included as well for silent operation and a great seal to the radiator.
PERFECT HEAT TRANSMISSION
Optimal FPI (fins per inch) is designed for low speed fans to guarantee silent operation
GREEN ENERGY
Protect environment by using RoHS compliant components, recycled materials and lead-free production
EASE OF USE
4 G1/4” threads and UNC 6-32 screw threads allow multiple and flexible installations and configurations
HIGH FLOW OPTIMIZED
Triple parallel rows minimize water resistance and achieve optimal cooling performance
THREE YEARS WARRANTY
Based on long-standing professional research, development and production
we provide full 3 years warranty on Coolgate heat exchangers
Specifications:-
- Tubes with 90% copper contingent
- Tubes Triple Row 13mm x2mm
- Material: Copper Fins, Brass Chambers
- 7 FPI (Fins per inch)
- 4 x G 1/4 Threads
- Weight: 1790 g
- Liquid Volume: 644 ml
- Pressure Tested: 1.5 Bar
- Dimensions: 473 x 142 x 60 mm
- n6-32 UNC threads on both sides for push pull with 140 mm fans
Only £64.80 inc VAT.
ORDER NOW
- Fan: 1x 92 mm
ORDER NOW
______
GREEN ENERGY
EASE OF USE
HIGH FLOW OPTIMIZED
Specifications:-
- 4 x G 1/4 Threads
- Weight: 1790 g
ORDER NOW
