**Today Only 02/07/2013** Enermx T.B.Silence UCTB12 120mm Fan & Samsung 120GB SSD 840 SATA 6Gb/s
22 Aug 2010
Today's deals! Snap em up
Enermax T.B.Silence UCTB12 120mm Fan @ £4.99 inc VAT
Low-noise Profile
Perfectly adjusted setting – optimal cooling performance and ultra silent operation.
Twister Bearing
Smooth and persistent silent thanks to patented Twister Bearing Technology (min. 100,000 hours MTBF).
Batwing Blades
Powerful cooling due to Batwing blades providing up to 20% higher air flow.
HALO Frame
Punched HALO frame for additional fresh air supply and effective reduction of air turbulences.
Modular Frame
Aluminium reinforced, three-piece frame design for a longer lifetime.
Click Mechanism
Detachable blades for easy cleaning from dust.
• Dimensions (mm): W120 x H120 x D25
• Bearing Type: atented Twister Bearing Technology
• Frame: punched HALO frame
• Blades: Batwing
• Number of Blades: 9
• Speed (RPM): 900 (+/- 10%)
• Air Flow (m3/h): 71.54
• Static Pressure (mm-H2O): 0.828
• Noise (dB(A)): 11
• MTBF: 100.000 hours
• Input Power (W): 1.8
• Rated Voltage (V): 12
• Accessory: 4 screws, 3P to 4P adaptor
Only £4.99 inc VAT.
ORDER NOW
Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) @ £71.99 inc VAT
The Samsung SSD840 is a high performance SSD designed for power users. Capable of delivering up to 98,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MDX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
• Capacity: 120GB
• Sequential Read: 530MB/s
• Sequential Write: 130MB/s
• Random Read (QD32, 4KB): 86,000 IOPS
• Random Write (QD32, 4KB): 32,000 IOPS
• Random Read (QD1, 4KB): 7,900 IOPS
• Random Write (QD1, 4KB): 29,000 IOPS
• Warranty: 3 Year
Samsung Cash Back Promotion for up to £50 cash back on your SSD *250GB basic and above
http://www.samsung.com/uk/ssdcashback/
Only £71.99 inc VAT.
ORDER NOW
are these fans any good for radiators? my apaches and arctic PWMs are getting a bit chatty! if not I'll just pick up some GTs when I have more money available to me :)
Picked up one of the fans for the exhaust on my case - I've already got 4 of the 140mm variants and have found them to be brilliant; completely in-audible as far as I am concerned and the build quality & overall finish on them is excellent.
The fans are quiet, however I suspect a large part of that is due to the fact they're slow.
I believe Enermax do a 'Magma' fan which is the same thing that spins faster. when you run them at full speed I think they're pretty loud or at least similar to fans of a similar speed.
