**TODAY ONLY! 02/07/2014** Asus Xonar Essence STX Sound Card & Blue Microphones SNOWBALL (White)
OcUK Staff
4 Feb 2013
Asus Xonar Essence STX Sound Card @ £109.99 inc VAT
The Xonar Essence STX PCI-Express is the latest sound card from Asus that provides high quality audio performance. Its integrated headphone amplifier produces less than 0.001% distortion to accompany its industry-leading 124dB Signal-to-Noise Ratio (SNR). The sound cards also boast Hyper-ground technology, EMI Shield design, AV100 high-definition sound processor, 24-bit Burr Brown PCM 1792A D-A converters, Nichicon Fine Gold capacitors, Optical digital output, Two pairs of RCA jacks and Input and output 6.3mm stereo jacks. The new Asus Xonar Essence STX PCI-Express is also perfect for gaming and entertainment PCs since it supports ASIO 2.0, Dolby Digital Live, Headphone, Virtual Speaker, Pro-Logic II home theater sound technologies and DS3D GX2.5 3D gaming engines.
- Optical digital output
- EMI Shield design
- Dolby Digital Live
- Pro-Logic II home theater sound technologies
- DS3D GX2.5 3D gaming engines
- 24-bit Burr Brown PCM 1792A D-A converters
- 124dB Signal-to-Noise Ratio (SNR)
Only £109.99 inc VAT.
ORDER NOW
_____
Blue Microphones SNOWBALL - White @ £53.99 inc VAT
Whether you're recording a guitar at your kitchen table or a complete band in the studio, the Snowball can capture sound with detail unheard of before in a USB mic. Plus, it's a direct plug and play mic that connects to either a Mac or PC - no additional software is needed.
Record anything from vocals to a full band
With its dual capsule design and unique three-pattern switch - cardioid, cardioid with -10dB pad, and omni - the Snowball can handle everything from soft vocals to the loudest garage band - and it's ideal for podcasting.
Highlights
- Professional condenser microphone
- USB powered
- Plug and play functionality
- Unique three-pattern switch
- Dual capsule design
What's in the Box?
- Snowball microphone
- 6-inch stand
- USB cable
Tech Specs:-
- Frequency Response: 40Hz - 18kHz
- Connections: USB
- Weight: 2.25 lbs.
- System Requirements
- Mac Mac OS X v.10.4.9 or later 64 MB RAM USB 2.0
- Windows Windows XP (SP2)/Vista/7
Only £53.99 inc VAT.
ORDER NOW
You Mr Anderp are a Saviour! :D The Snowball is just what my Nephew wants for his birthday. I also had enough in my Paypal account to pay for it too!
Asus Xonar Essence STX will finish my rig off nicely, Now to start the process of braiding cables and improving airflow.
