Today we feature two fantastic monitors at great pricing.
The Dell monitor is in a league of it's own with IPS panel displaying producing the best viewing angles and a resolution of 1920 x 1200. This monitor is recommended to professionals.
The Iiyama monitor is a great gaming monitor. With a 2ms response time and 1920x1080 resolution, this monitor is recommended for avid gamers.
Dell UltraSharp U2410 24" Widescreen LCD Monitor - Midnight Grey @ £340.00 inc VAT
Experience astounding colour accuracy, precision and performance with the Dell UltraSharp U2410 Monitor. The U2410 is packed with features that make it easy to connect and a pleasure to use, no matter how much screen time you log including Picture-in-Picture, adjustable stand, touch controls and extensive connectivity. Thanks to PremierColor technology, the U2410 Monitor delivers reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. A colour gamut of 110% delivers vibrant, true-to life colour across all display modes.
- Screen Size: 24" IPS Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 80000:1
- Brightness: 400cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Component, 1x Composite, 1x VGA, 1x DisplayPort, 2x DVI-D & 1x HDMI
- Adjustable Stand
- VESA Compliant
- Dimensions: 559.7mm x 493.0mm x 201.5mm
- Warranty: 3 Years On-Site (Dell Premium Guarantee - You will receive a replacement UltraSharp monitor should even one bright defective pixel appear on the screen)
Only £340.00 inc VAT.
ORDER NOW
Iiyama ProLite E2409HDS 24" Widescreen LCD Monitor - Black @ £119.99 inc VAT
Iiyama's ProLite LCD, the E2409HDS is the latest product to follow the true HD resolution of1920x1080. The incredible 2ms Response Time and 20000:1 Contrast Ratio panel ensures vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs.
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 20000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 7.7kg
Only £119.99 inc VAT.
ORDER NOW
- Adjustable Stand
- VESA Compliant
ORDER NOW
- VESA Compliant
- Adjustable Stand
- Weight: 7.7kg
ORDER NOW
