Creative Sound Blaster Audigy Fx OEM (CL-30SB157000001) @ £19.99 inc VAT
The perfect Sound Blaster upgrade The Sound Blaster Audigy Fx is a half-height sound card that's powered by SBX Pro Studio technology. It instantly converts your system to a 5.1 entertainment system that delivers cinematic surround sound - perfect for bringing out the best in your movies, music and games! The Sound Blaster Audigy Fx also features a 24-bit 192kHz digital-to-analog converter (playback), 106dB SNR and a high-end 600-ohm headphone amplifier for studio-grade monitoring. Interchangeable full-height and half-height metal brackets are included to give you the flexibility of installing the sound card in small form factor desktop PCs.
Enjoy multi-channel cinematic sound The half-height PCIe sound card is just the perfect size for your home theatre PCs. You can now upgrade your cinematic experience with Sound Blaster audio fidelity. Sound Blaster Audigy Fx comes with 5.1 channel outputs so you can connect to your existing multi-channel speakers with ease.
Independent input sources Sound Blaster Audigy Fx comes with independent line-in and microphone connectors, which allow you to plug in two different audio sources to your PC.
Specifications:-
- Signal to Noise Ratio: 106dB
- Sound Output Mode: 5.1
- Standards: SBX Pro Studio
- Sample Rate: 16-bit to 24-bit playback sampling rates: 44.1, 48, 96, 192kHz‚16-bit to 24-bit recording sampling rates: 44.1, 48, 96kHz
- Compatible OS: Windows Vista‚Windows 7‚Windows 8
- Package Type: OEM
DAC Data Width : 24 bit
Interface: PCI Express x1
Connectivity: Headphone/Front Out: 1 x 3.5mm jack‚Rear Out: 1 x 3.5mm jack‚Centre/Subwoofer: 1 x 3.5mm jack‚Microphone In: 1 x 3.5mm jack‚Line In: 1 x 3.5mm jack
Special Features: 5.1 PCIe Sound Card with SBX Pro Studio‚Enjoy multi-channel cinematic sound‚Independent input sources‚Headphone Amp up to 600 Ohms‚24-bit 192 kHz Stereo Direct
Only £19.99 inc VAT.
ORDER NOW
_____
MSI GS702OD-409UK STEALTH 17.3" True HD LED, Intel i7-4700MQ, 8GB DDR3, 128GB SSD & 1TB HDD, NVIDIA GTX 765M 2GB - Windows 8 Laptop @ £999.95 inc VAT
The MSI GS70 Stealth is the company's thinnest gaming laptop yet. At a mere 2.2cm (22mm) thick and weighing less than 2.6kg, the all-black laptop comes dangerously close to Ultrabook territory, but still manages to squeeze in a 17inch Full HD display and NVIDIA dedicated graphics.
Hot on the heels of Razer's refreshed Blade laptops, the GS70 Stealth is constructed from aluminium and feels absolutely amazing quality wise with zero flex or give in the chassis.
Powered by Intel 4th generation Haswell processors along with 8GB of Dual Channel DDR3 RAM, but most impressive is the onboard NVIDIA GTX 765M 2GB GDDR5 graphics which can power through the latest games such as Tomb Raider and Crysis 3.
Even though the GS70 Stealth is considerably lighter in weight compared to the other MSI GX70 gaming models, it is still feature packed including multi-colour backlit keyboard developed by Steelseries, KillerNIC gaming-grade network card.
Even with the GS70's ultra slim proportions you still get four USB ports, Ethernet, audio jacks, card reader, HDMI port and two Mini-Display ports. You can use the three graphic outputs at once if you have three monitors for NVIDIA Surround Gaming on the GTX 765M.
Considering the MSI GS70 Stealth is thinner and lighter than the Razer Blade along with a better specification, whats even better it cost less and is available here in the UK with MSI's amazing warranty support.
Get a true style icon with immense build quality today with the MSI Stealth which is arriving with Overclockers UK before any competitor by at least a month!!!
Specification:
- Screen Size: 17.3"
- Screen Type: LCD
- Backlight: LED
- Screen Resolution: 1920x1080
- Aspect Ratio: 16:9
- Screen Features: Full HD
- Processor Type: Intel Core i7 4700MQ
- Processor Cores: 4 (8 Threads)
- Processor Clock Speed: 2.40GHz (3.30GHz Turbo Mode)
- Hard Drive Supplied: 1 x 1000GB
- Hard Drive Size: 1000GB
- Solid State Drive: 128GB SSD x1
- Hard Drive Interface: Serial ATA-600
- Hard Drive Speed: 5400RPM
- Memory Supplied: 2x 4GB
- Memory Size: 8GB
- Memory Type: DDR3
- Memory Speed: 1600
- Memory Socket: 2 x SO-DIMM
- Max. Memory Support: 32GB
- Operating System: Windows 8
- Graphics Chipset: NVIDIA GeForce GTX 765M
- Graphics Memory: 2GB GDDR 5
- Chipset: Intel HM87 Express
- Audio: Sound by Dynaudio
- Speaker(s): 2 x Speakers
- Subwoofer: 1 subwoofer
- Microphone: Built-in
- LAN Card: Killer E2200 LAN
- LAN Speed: 10/100/1000
- Wireless NIC: Killer N1202 Combo (2*2, a/b/g/n)
- Bluetooth: v4.0
- USB 3.0 Port(s): 4
- HDMI Port(s): 1
- Mini Display Port(s): 2
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- Line In Jack(s): 1
- Line Out Jack(s): 1
- LAN Port(s): 1
- Battery Life: 4hrs
- Card Reader: SDXC/HC
- Web Camera: HD type ( 30fps@720p)
- Only 22mm thick
- Product Weight (g): 2.6Kg (w/Battery)
- Supplied with FREE Protective carry case
- Kitguru Review: http://www.kitguru.net/laptops/zardon/msi-gs70-2od-stealth-17-3-inch-laptop-review/27/
- Warranty: 2 Years
Only £999.95 inc VAT.
ORDER NOW
Specifications:-
- Package Type: OEM
ORDER NOW
_____
Specification:
- Screen Type: LCD
- Backlight: LED
- Memory Size: 8GB
- Memory Type: DDR3
- Bluetooth: v4.0
- HDMI Port(s): 1
- LAN Port(s): 1
- Only 22mm thick
- Warranty: 2 Years
ORDER NOW
