**TODAY ONLY! 03/06/2014** Zalman LQ315 Ultimate Liquid Cooler & Zowie Celeritas Pro Gaming Keyboard
OcUK Staff
4 Feb 2013
Zalman LQ315 Ultimate Liquid CPU Cooler @ £59.99 inc VAT
Zalmans new LQ315 Ultimate cooling solution for Intel and AMD sockets with Micro Fin copper instead of standard blocks, this helps spread the heat evenly and ensures a cooler and gives the ability to get higher clocks from your CPU.
Features:-
- Blue LED Water Block
- Zalman High quality radiator cover
- Easy installation and maintenance
- Slim water block design ability to fit within ATX Cases
- Micro Fin Copper Base ensuring effect heat transfer
- High compatability with all Intel and AMD Sockets
- Eco friendly corrosion prevention coolant
- Ability to support Duel 120mm fans
Specification:-
- Materials: Pure Copper, Aluminum
- Water Pump: Enclosed Type
- Tube Length: 300mm
- Power: 300w
- Rated Voltage: DC12V
- Water Block Weight: 195g
- Weight: 515g
- Dimensions: 153(L) x 120(W) x 28(H)mm
Only £59.99 inc VAT.
ORDER NOW
_____
Zowie Celeritas Pro Gaming Keyboard (MX Red), Black - UK Layout @ £71.99 inc VAT
Technical details:
- Dimensions: 440 x 37 x 162 mm (W x H x D)
- Color: Black
- Weight: 1,2 kg
- Layout: English
- Switches: Cherry MX Red
- Connections:
USB (gold-plated)
PS2 adapter included
Cable length: 1.8 m
Repetition time:
32 ms 1x =
2x = 16 ms
8 ms = 4x
8x = 4 ms
Features:
Compact design (space-saving)
Very sturdy construction with metal frame
Anti-Ghosting: 6x USB / PS2 full with
adjustable repetition time (4 steps)
Selectable Logo Illumination: Blue / Red
multimedia keys
Only £71.99 inc VAT.
ORDER NOW
For a standard thickness 120 rad loop?
Doubt it.
What improves cooling is surface area and louder fans.
This one might be thicker than standard tho, can't see clearly.
