MSI HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card with FREE Sleeping Dogs PC Game @ £299.99 inc VAT
As AMD is going to launch its latest HD 7000 series GPU on Jan. 9th, 2012, MSI also will release R7970-2PMD3GD5 graphics card at the same time. MSI R7970-2PMD3GD5 has exclusive GPU Overvoltage support through MSI's Afterburner utility allowing amazing overclocked performance from the get-go. Equipped with 3GB GDDR5 memory allows for the unprecedented memory bandwidth levels needed to run today visually hottest DirectX 11 titles at extreme resolutions across multiple displays. Stability is guaranteed through the use of All Solid Capacitors making sure the R7970-2PMD3GD5 and R7950-2PMD3GD5 have an ultra-long lifespan even under the stress of continuous gaming. DisplayPort 1.2 and HDMI 1.4a connectors allows all new audio and video formats like Blu-ray 3D Stereo, "Deep Color" (for true natural color representation) and 7.1 High Bitrate audio to be presented on up-to six displays through AMD's Eyefinity Technology.
MSI's R7900 series graphics cards are the first graphics cards in the world to support the new PCI Express Gen 3 format. With a processor and mainboard that has PCI Express Gen 3 capability, users will be able to enjoy maximized gaming performance via the ultra-high 32GB/S bandwidth. The R7900 series graphics cards have also adopted the brand new AMD 28nm graphics chip to provide higher performance computing compared to previous generation 40nm products.
MSI's R7970-2PMD3GD5 graphics cards are equipped with the popular Afterburner tuning software, allowing users to adjust the core voltage and improve overclocking potential. In addition, Afterburner also features bundled Predator in-game video capture, remote monitoring capabilities via mobile phone, as well as Kombustor GPU stress testing and other amazing features at no extra charge, providing an exceptional software suite for users of the HD 7000 series graphics cards.
MSI's R7900 series graphics cards support AMD's exclusive Eyefinity multi-monitor display technology. The expanded field of view is perfect for professionals and hardcore gamers. The new MSI R7900 series cards support next-generation Display Port 1.2 and HDMI 1.4a interfaces with stereoscopic 3D capability, as well as 7.1 channel lossless high quality TrueHD and DTS-HD audio formats, providing users with the best audio and visual experience possible.
MSI's R7970-2PMD3GD5 has adopted all solid capacitors. The aluminum core is capable of maintaining a high degree of stability even when working under full loads over extended periods of time. With a 10-year lifespan, MSI rids users of concerns over potential crashes or delays that are caused by system hardware overheating, further providing users with the best computing experience possible.
Features:-
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1010MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5500MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
- All Orders placed on the 30th August 2012 and after shall recieve a FREE copy of Sleeping Dogs PC Game worth £29.99 completely FREE (Subject to availability) - You will recieve your gamecode from 7th September onwards in the email address you provided when placing your order!
Was £329.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Roccat Kone V2 Max Customisation Gaming Mouse @ £26.40 inc VAT
Stuffed with technology and design innovations, the gaming mouse ROCCAT™ Kone is the only tool to unleash your hidden skills and develop your existing ones to the max. The precise Pro-Aim Gaming Sensor effectively reduces Pick-Up-Flight. It is accompanied by a high-end 6.4 megapixel sensor measuring with 7080 frames per second, loss-free up to a velocity of 20G. 1ms response time, 1000Hz polling rate and the adjustable resolution up to real 3200dpi give you the competitive edge to improve your aiming skills.
- 3200 DPI Pro-Aim Gaming Sensor
- TCU: Tracking Control Unit
- Integrated Turbocore (internal CPU built into the mouse)
- Onboard Memory (128KB) allowing you to save up to 5 gaming profiles
- Ergonomic Hybrid Shape
- Customizable Light System: 5 LED's capable of displaying the full spectrum of colours
- Customizable weighting (5g, 10g, 15g and 20g weights)
- NEW IMPROVED SCROLL WHEEL WHICH CAN TAKE UPTO 1.5KG MORE LOAD COMPARED TO THE ORIGNAL ROCCAT KONE MOUSE
Was £34.99 Inc. VAT
Only £26.40 inc VAT.
ORDER NOW
Features:-
- 3yr Warranty
ORDER NOW
Was £34.99 Inc. VAT
ORDER NOW
