**Today Only 03/10/2012** PC Power & Cooling Silencer Mk III 600w & AMD Phenom II X4 Quad Core 955
22 Aug 2010
Today Only Dealios! Make sure you look through our this week only deals to
PC Power & Cooling Silencer Mk III Series 600W '80 Plus Bronze' Modular Power Supply - White @ £56.99 inc VAT
Building on the design expertise of its predecessors, the Mk III once again refines the Silencer lineup and defines the ideal power management solution for performances users. Engineered meticulously with only premium components, the Mk III balances the needs of server-class and IT professional standards, including 100% Japanese 105°C capacitors, continuous output at a demanding 50°C ambient temperature, and heavy-duty protection circuitries. Key features include a 120mm variable RPM fan for quiet operation, well regulated electrical noise and ripple, modular cable management system, 80 Plus Bronze-level efficiency, and comes backed by a 5-year warranty for ultimate peace of mind.
- Continuous output rated at a demanding 50¢XC ambient temperature
- Built with 100% Japanese low ESR 105¢XC capacitors for high reliability
- Single +12V rail for efficient power distribution in your system.
- Compliant with the latest ATX12V v2.3 standard for worry-free compatibility
- A large temperature and load controlled 120mm double ball-bearing fan for whisper quiet operation
- 80PLUS Bronze certified for up to 85% efficiency under real world operating environments
- ErP compliant for low power usage in standby or off mode.
- Active Power Factor Correction (PFC) to effectively regulate input voltage
- Heavy-duty protection circuitry, (over-voltage, over-power, and short circuit) for protecting your valuable components
- Safety Approvals: cTUVus, CE, CB, FCC Class B, TUV, CCC, C-tick
Only £56.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail @ £59.99 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.20GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- HyperTransport 3.0
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Only £59.99 inc VAT.
ORDER NOW
