Get a lovely, shiny, silent case - and get some new memory to boot!
OcUK Tech Labs - Lian Li PC-7HA Midi-Tower Case - Silver - Noise Dampened @ £105.58 inc VAT
OcUK understand that our customers are looking to strive for that little extra over any other customers. We know that many of you strive for quiet computing, some of you spend literally hundreds of pounds on watercooling to reduce noise! Well we have listened (no pun intended, honest) and created a range of cases which are pre-installed with amazing high quality accoustic dampening pads, which are finished off with a leather style surface to provide that extra level of premium quality that should be given to you; our customers!
This Tech Labs case includes the standard case in its default format as produced by the manufacturer but our expert technicans have spent time dampening it with our Foam Dampening Kits!
- Default case; but noise insulated
- Pre-installed for your convience
- All foam dampening pads have a leather style finish surface
- Reduced accoustics
Only £105.58 inc VAT.
ORDER NOW
_
TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (TXD38G2400HC10QDC01) @ £59.99 inc VAT
Team Xtreem LV is the most popular overclocking and gaming gear in the LAN party. Based on the memory architecture evolution on Intel Core i7, Team raises the frequency of the Xtreem LV DDR3 by 20% from 2000MHz to 2400MHz. Also, by continuing the high frequency and low latency tradition of the Xtreem LV memory, the Xtreem LV DDR3 2400 can fully display the configuration 9-11-11-28 (tCL-tRCD-tRP-tRAS) at a low operating voltage at 1.65V without sacrificing either performance or stability. All these have witnessed the extraordinary R&D capacity and capability of Team. In addition to the unchanged genuine chip policy, Team ensures chip quality with the exclusive sorting technology to screen chips. In order to further ensure the optimal performance and flawless quality of the Xtreem LV DDR3 2400, Team applies the 24-hour burn-in test and industry-approved MemTest software to perform the OQC inspection of all modules before shipping to assure the stability and exceptional performance of every Xtreem LV DDR3 2400. The Xtreem LV DDR3 2400 from Team has a conventional 8-layered PCB design and is covered with the X-mark heat-sink labeled for the Xtreem series. In addition to the clean appearance as found in all Team Xtreem memory modules, a groove has been added to the heat-sink for power users to install fans on top to enhance ventilation. For more information on this product, please visit the Team Group website at: www.teamgroup.com.tw.
Features:-
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 10-12-12-31
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 19,200MB/Sec (PC3 19200)
- Heat Sink Aluminum heat-sink
- Working voltage 1.65V
- Warranty Lifetime warranty
- Note Intel XMP1.3, compatible with series Intel 7 chipsets and higher.
Only £59.99 inc VAT.
ORDER NOW
ORDER NOW
_
Features:-
ORDER NOW
