**Today Only 03/11/2011** Iiyama Prolite X2377HDS 23" IPS LED Monitor & OcUK Value 8GB 1333Mhz DDR3
22 Aug 2010
If you love great quality monitors, you will love IPS panels. With the best viewing angles you can get and LED backlit , this monitor is a steal for only £164.99 inc. VAT.
If you are on a tight budget but the computer really could do with an upgrade of memory, now is the time to grab a cheap kit of 8GB DDR3 memory for only £23.99 inc VAT saving you £6!!
Iiyama Prolite X2377HDS 23" Premium IPS Panel Widescreen LED Monitor - Black @ £164.99 inc VAT
ProLite X2377HDS - A 23” LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all around panel type. This IPS panel offers accurate and consistent colour reproduction with wide viewing angles (178°/178°) and great response time (5 ms black-to-black). The ProLite X2377HDS is full HD, has a 5 000,000:1 Advanced Contrast Ratio and 250 cd/m² brightness offering the user clear and vivid images. An array of inputs including HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. The Prolite X2377HDS has two integrated stereo speakers and is VESA mount compatible. It will provide both excellent performance for photographic, design and web-design and is also an excellent choice for Universities, Corporate and Financial Markets, as well as the rapidly expanding demand for Multi Monitor applications.
Features:-
- Diagonal 23" Panel IPS
- Display area h x w 286.4 x 509.2 mm; 11.3" x 20"
- Response time 5 ms
- Contrast 1000 : 1 typical
- Contrast 5 000 000 : 1 ACR
- Brightness 250 cd/m² typical
- Viewing zone horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour 16.7 million Pixel pitch h x v 0.265 x 0.265 mm
- Native resolution Full HD 1080p, 1920 x 1080 ( 2.1 megapixel) Horizontal sync 30 - 80 KHz Vertical sync 55 - 75 Hz Synchronization Separate sync
- Aspect ratio 16 : 9
- VGA, DVI & HDMI inputs
- 3yr Warranty
Only £164.99 inc VAT.
ORDER NOW
OcUK Value 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit @ £23.99 inc VAT
OcUk Value Series Memory is designed to optimized the high performance DIMMs for reliability in order to ensure your system does not fail you, while maintaining a solid overclock to prevent a mid-game PC failure from memory errors.
Features:-
- Cas latency: 9-9-9-24-2N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1333 (PC3 10666)
- Test voltage: 1.5 Volts
- Type: 240-pin DIMM
- Warranty: Lifetime
- Sandybridge compatible
Only £23.99 inc VAT.
ORDER NOW
The iiyama 23" IPS is a stunning bit of kit, great colours, amazing viewing angles and still with a fast response time and the price is very very good for this type of monitor. :)
Well, i was all set to order the Asus ML239H which is the same price as the Iiyama (today)
http://www.overclockers.co.uk/showproduct.php?prodid=MO-025-AS&groupid=17&catid=1425&subcat=
The asus has 'trace free' settings which does a good job, according to tftcentral, of dealing with any motion blur and ghosting. I can't find any reviews on this new Iiyama but the extra connection over the asus it is quite tempting.
I just don't know what to do now!
Edit: i was also thinking of waiting a little longer as a lot of manufacturers seem to be using IPS panels now as they seem to have come down in price.
That ram price is so daft its worth almost buying just for the sake of it :)
would I notice any difference whatsoever in my whs2011 box with 8gb in over the 4gb thats currently in?
Hi there
What is this extra connection your saying the iiyama has as I must have missed it?
Hi Gibbo, the Iiyama has
1 x VGA
1 x DVI
1 x HDMI
but the ASUS only has
1 x VGA
1 x HDMI
so if i got the ASUS i would want to connect my pc via the HDMI but i also have a PS3 which i would want to connect using the HDMI. Getting the Iiyama would let me connect my pc via the DVI port and the PS3 via the HDMI.
Ram that cheap, is worth getting a new mobo and chip to match for my sisters system, instead of paying silly money for corrupted 2nd hand ddr2
