**Today Only 03/12/2010** Corsair Dominator 4GB 1600MHz RAM & Arctic Cooling Freezer 7 REV2 CPU Cool
22 Aug 2010
Today Only, two cracking deals to save you money without sacrificing quality. Do not miss out!
Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMD4GX3M2A1600C9) @ £64.61 inc VAT
This 4GB twin DOMINATOR kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock.
- Corsair Dominator memory (2 x 2GB)
- Form factor: DIMM 240-pin
- Memory speed: 1600 MHz
- Latency timings: CL9 (9-9-9-24 )
- Dual-path Heat Xchange (DHX)
- Intel Extreme Memory Profiles (XMP)
- Supply voltage: 1.65 V
- Built for Intel
Only £64.61 inc VAT.
ORDER NOW
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1156 / 1366) @ £15.98 inc VAT
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users.
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient. Featuring a 92mm PWM fan , 6 heatpipes and pre-applied ARCTIC MX-2.,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity – becoming one of the most efficient CPU coolers for power users.
- Compatable Sockets: 939 /AM2 /AM2+ / 775 / 1156 / 1366
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Only £15.98 inc VAT.
ORDER NOW
How can they make, pack & ship that cooler for 15 quid. :confused:
Am Loving all these deals but am having trouble choosing which to buy. :p
I get how it works but in my own head I wouldn't deliver that to OcUK HQ for 15 quid let alone build,pack & then ship it. :p
They probably cost like £5-7 per unit to make.
Correct due to the volume they produce then cost per unit drops. The biggest part of the cost is the actual manufacturing process, not the material costs. So the more they make, the cheaper each unit costs.
It's simple supply vs demand = cost
Considering each one only costs them pennies to make, and its retailing for £18 (on sale now for £15) they have a massive price up and heir profits will be in the X x1000%'s per one.
