- 20 Jul 2009
- The bleak North East arm pit of Britain
Today Only, we have 15 units of OCZ StealthXStream 2 600W Power Supply for only £50.99 inc. VAT. The StealthXStream 2 is equipped with four 12v Rails for a reliable, stable power delivery whilst delivering an 82% typical load efficiency.
We also have 15 units of Coolermaster Inferno 4000dpi Laser gaming Mouse for just £25.98 inc. VAT. Equipped with dual 4000dpi sensors the Inferno is at the top of its game striking the perfect balance between performance and affordability.
OCZ StealthXStream 2 600W Power Supply @ £50.99 inc VAT
The new StealthXstream II strikes the right balance between mainstream power needs and high-performance build quality to deliver unprecedented value. Designed for both gamers and mainstream power users in mind, key features of the sleek StealthXstream II include a thermally controlled 120mm double-ball bearing fan maximum airflow at near-silent audible noise levels, exceptionally well regulated electrical noise and ripple for stable operation, an ideal array of connector types for each wattage, and excellent efficiency, converting up to a full 82% of AC to DC power at typical loads. The StealthXstream II Series from OCZ is fully compliant with the latest ATX12V and EPS12V specifications.
- Series: StealthXstream II
- Type: ATX12V V2.2 / EPS12V
- Wattage: 600W
- Fan Size: 120mm double ball-bearing
- PFC: Active
- Main Connector: 20+4-Pin, +12V Rails: 4, PCI-E Connector: 1 x 6-Pin +, 1 x (6+2-Pin) PCI-E, SATA Power 4
- Efficiency: Typical load 82% Efficiency
- Energy Certifications: 80 PLUS Certified
- Input Voltage: 100 – 240V
- Input Frequency Range: 50/60 Hz
- Output: +3.3V@25A,+5V@25A,+12V1@18A, +12V2@18A, ,+12V3@18A, +12V4@18A
- [email protected],+5VSB @ 3.0A
- Dimensions: 15cm x 8.5cm x 14cm (W x H x L)
- Connectors: 1 x Main connector (20+4Pin), 1 x 8 (4+4) Pin, 1 x 6-Pin PCI-E, 1 x 6+2-Pin PCI-E, 6 x Peripheral, 4 x SATA, 1 x Floppy
Was £56.16 Inc. VAT
Only £50.99 inc VAT.
ORDER NOW
Coolermaster Inferno 4000dpi Laser Gaming Mouse @ £25.98 inc VAT
Mobilized to deploy any Storm Ops in heaving light-speed, the Inferno is fortified with an ultra precise 4000 DPI twin laser sensor, a boosted internal 128k Sentinel-X™ memory, and enhanced with our latest patented technology for MMORPGers – the Storm Tactics™ Multiplier key. Designed for total customization, with heavy macro and script capabilities inside, the Inferno is built to actuate ultra fast combo commands – remarkably in faultless precision.
- Superior Gaming-grade Percision
- Onboard Sentinel-X 128KB memory for 3 gaming profiles
- Advance Storm MacroPro Key
- Rapid Fire Tactical Key
- Storm Tactics Multiplier Key
- Rubber Grip / ABS Plastic / Mesh Bezel / Metal Plate
- 4000 DPI Storm Tactical™ Laser Sensor
- Tracks on all surfaces, lift-off distance 2mm
Was £29.60 Inc. VAT
Only £25.98 inc VAT.
ORDER NOW
- Wattage: 600W
- PFC: Active
Was £56.16 Inc. VAT
ORDER NOW
Was £29.60 Inc. VAT
ORDER NOW
