**Today Only 04/02/2012** Corsair XMS3 8GB Dual Channel Memory Kit & Creative Tactic3D Wrath Wireles
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
This weekend we have another 2 excellent deal for you.
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £31.99 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
- Sandybridge compatible
Was £43.99 Inc. VAT
Only £31.99 inc VAT.
ORDER NOW
Creative Sound Blaster Tactic3D Wrath Wireless Headset @ £90.98 inc VAT
Unleash the power of Sound Blaster and THX® TruStudio Pro™ without the wires. The special edition Sound Blaster Tactic3D Wrath Wireless Headset combines the legendary Sound Blaster audio quality with a slick design featuring illuminated ear cups housing massively powerful 50mm FullSpectrum™ Speakers, a removable microphone, integrated volume and mute controls, and uncompressed wireless technology designed and meticulously tuned to deliver THX TruStudio Pro-enhanced audio on your PC or Mac. Get yours and start experiencing the Sound Blaster advantage today!
THX TruStudio Pro (PC & Mac)
THX TruStudio Pro sound technologies for PC and Mac create unprecedented levels of audio realism that includes stunning surround effects to produce virtual speakers around, above and below you.
High caliber wireless gaming headset
The simple yet powerful Wrath Wireless USB transmitter transmits and receives uncompressed wireless audio to and from your PC or Mac, ensuring you lag- and static-free pro-gaming audio with uncompromised detail.
50mm FullSpectrum Speakers
A high-powered, no holds barred 3D gaming audio experience with massive bass and detailed highs - exactly how the game designers want you to experience the game.
Built like a tank
Built around a steel core, the Sound Blaster Tactic3D Wrath Wireless headset is fabricated to withstand the rigors of intense gaming or being chucked in a backpack. Keep it at home or take it with you without any worries.
Illuminated earcups with onboard controls
Style meets function with slick illumination and volume, mute and connection controls fully integrated into the earcup.
Detachable microphone
Detach the microphone and use the Sound Blaster Tactic3D Wrath Wireless as high-quality wireless headphones for music and digital entertainment.
Over 400 Million Sound Blasters sold
Experience the difference of REAL audio expertise. The industry standard for audio quality on the PC is now also available on Mac®
Customize and share optimized audio settings
Customize your own TacticProfile™ EQ and audio profiles, and then export and share them with other gamers.
• 50mm FullSpectrum Speakers.
• Li-ion rechargeable battery.
• Illuminated earcups with on-board controls.
• Detachable microphone.
• Customize and share optimized audio settings.
Was £97.98 Inc. VAT
Only £90.98 inc VAT.
ORDER NOW
DAMMIT OcUK!
I swear you look at what I have just bought to put on daily deal.
Anyway I can vouch for the Creative Wrath its really good. Range could be better but I only ever use it in my room for which it is fine and the sound is really good definitely worth the money for a wireless headset. Also the red lights are cool.
Wow... very interesting all your information.
I'm going to replace mi old Asus AMD for a new one.
There is a lot of awesome information around here.
See you...!!
