**Today Only 04/04/2012** NZXT Phantom Enthusiast USB3.0 - RED & Antec Soundscience Halo 6 LED
22 Aug 2010
Today Only Deals!!!!
NZXT Phantom Enthusiast USB3.0 Full Tower Case - Red @ £91.98 inc VAT
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs – we run the extra mile so you won’t have to settle with the typical rectangular box. The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25” screwless system, vast space to encompass 7 hard drives, and five 5.25” bays enable smooth customization. Establish your power, your presence.
- High Performance Cooling Advantages
– Phantom’s extensive cooling capabilities include 7 fan cooling options with dual 200mm, single 230/200mm, triple 120mm, and front 140mm fan options
- NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
- Simple Installation
– Phantom celebrates an array of innovative features designed to enhance every stage of the build
- Meticulous cable management is easily attainable with large spacing behind the motherboard.
- Innovative all-new 5.25” screwless rails make installing and swapping HDDs an effortless process
- Rubber grommets dampens vibration during operation.
- LED on/off button to control fan lighting
- Rubber PSU and case feet to reduce vibration
- Easily removable front and top panels
- Top mounted USB, Audio/Mic, and E-SATA ports.
– Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today’s hottest components
- Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25” bays
Only £91.98 inc VAT.
ORDER NOW
Antec Soundscience Halo 6 LED Bias Lighting Kit @ £7.98 inc VAT
The soundscience halo 6 LED bias lighting kit™ makes it easy to outfit your monitor with professional backlighting. Bias lighting is an illumination technique for reducing eye fatigue and increasing perceived image clarity during long gaming sessions and extended periods of computer use. The halo 6 LED bias lighting kit™ adds a subtle white backlight to your monitor, reducing the eyestrain caused by differences in picture brightness from scene changes in movies, TV shows and video games. The color and brightness of the LEDs are carefully calibrated to achieve the optimal viewing experience. Bias lighting also increases your monitor’s perceived contrast ratio – making blacks blacker and colors more vibrant. Installation is easy – simply attach the LED strip to the back of your monitor and insert the USB plug into an open USB port on your computer or powered USB hub. The soundscience halo 6 LED bias lighting kit™ complements any monitor up to 24” in size.
- Requirements: LCD monitor up to 24” in size placed against light colored wall; available USB port or powered USB hub
- Certifications/Safety: CE, RoHS
- Unit Dimensions: Cable: 1300 mm / Light Strip: 370 mm
- Net Weight: 1.0 oz / 28.3 g
- Product Warranty: 2 year
Only £7.98 inc VAT.
ORDER NOW
