**TODAY ONLY! 04/06/2015** NZXT HUE RGB LED Controller & Arozzi Torretta XL Gaming Chair
OcUK Staff
4 Feb 2013
NZXT HUE RGB LED Controller - Black @ £19.99 inc VAT
NZXT has expanded their bay devices with HUE; an LED configuration that is customizable to your liking. HUE grants you the power to select how you want to illuminate your chassis with infinite possibilities. Take charge of the RGB controls to adjust the color fade, pulsating light effects, and brightness levels of your internal LED sleeve. HUE is equipped with an on/off mode for times you may need to go stealth and possesses a unique semi-mesh design, blending flawlessly into any chassis with a mesh front panel.
- Infinite color options that you can customize to your heart’s content
- Three RGB controls to adjust the color settings, brightness level, and pulse speed of the internal LED sleeve
- On/off mode to completely disable the LEDs
- Effect modes: normal, fading, flashing, and pulsating of colors
- Internal LED sleeves that vibrantly illuminates and accents your chassis based on your liking
- Unique mesh design that blends flawlessly into any chassis with a mesh front panel
- 5.25" ODD
- 3 RGB dials
- 5 Brightness Levels
- Modes: NORMAL, FADING, FLASHING, COLOR FADING, AND COLOR FLASHING
Only £19.99 inc VAT.
ORDER NOW
______
Arozzi Torretta XL Gaming Chair - Azure @ £139.99 inc VAT
The Arozzi Torretta XL is one cool gaming chair, which has a racing inspired look. High quality, thick padding on the arm rests, seat and, back gives you the highest comfort.
The Torretta XL chair is one of the first chairs to be designed for people with the need of a larger and wider chair. With the same features and design as its precursor, but with wider seat and backrest this chair will bring supreme comfort without feeling tight.
Features
- Colour: Azure & Black
- Metal frame construction.
- Thick padded seat and backrest.
- Ergonomic design.
- Fabric upholstery material.
- 360 Degree swivel rotation.
- Adjustable armrest (height and rotation)
- Adjustable height gas-spring, supports up to 180KG.
- Tiltable seat with lock function
- Lightweight construction for easy movement.
- Five twin wheel nylon casters.
- 7 different colour choices.
Technical Details
- Shoulder Width: 590mm
- Waist Width: 450mm
- Seat Width: 480mm
- Chair Height: 1280mm
- Seat Length: 460mm
- Seat Height: 400-330mm
- Armrest Heights: 370-270mm
Only £139.99 inc VAT.
ORDER NOW
What LED's do you get with this? Are there several that can be placed inside your case? Or is it just ones built into the actual unit itself? Or do you need to buy the LED's to go with it?
The NZXT is a great gizmo - till it burns out.
Both mine and my friends have died - in my case I could smell the burning when it went (thankfully).
It comes with a strip of LEDs which are self adhesive (one long strip) which you can affix to the case. They will need cable ties to keep them on longer term though.
