**Today Only 04/07/2012** AOC E2795VH 27" Widescreen LED Monitor & Corsair Vengeance 16GB 1600MHz RA
22 Aug 2010
Today Only Deals! Save up to £56 :)
AOC E2795VH 27" Widescreen LED Monitor - Black @ £179.99 inc VAT
No compromises: The e2795Vh is perfect for office and action. This Full HD large-screen monitor with integrated speakers not only looks fantastic. The generous 16:9 display area offers ample space for complex charts, double-page spreads, image editing, games, videos or movies. High contrast and brightness values in combination with wide viewing angles and a fast response time provide an excellent image quality without blurring from almost every perspective. Thanks to DVI-D and HDMI inputs (with HDCP) high-resolution content from numerous video sources is displayed flawlessly. With electricity-saving LED backlights and a mercury-free manufacturing this flatscreen is also easy on the environment.
Features:-
- Screen Size: 27" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 20,000,000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Contrast Ratio Typical 1.200:1
- Pixel / Dot / Pitch 0.3114 (H) x 0.3114 (V)
- Display Area 597.6 (H) x 336.15 (V)
- Viewing Angles (H/V): 170°/160°
- Special Features: DCB,e-Saver,i-Menu,Kensington Security Lock,screen+,SRS,USB,Wide View Angle
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Warranty: 3 Years On-Site
Only £179.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (CMZ16GX3M2A1600C10) @ £89.99 inc VAT
The new 16GB Vengeance DDR3 kits operates at 1.5V for compatibility with the new 2nd generation Intel® Core™ processor family and is guaranteed to operate at 1600MHz. Providing 8GB of rigorously-screened DRAM on a single module allows gamers and performance enthusiasts to build systems with 32GB of high-performance memory.
"Vengeance DDR3 memory is the premier choice for reliable, overclockable DRAM for system builders on a budget," said Giovanni Sena, Director of Memory Products at Corsair. "Our kits based on 8GB modules give builders, system integrators, and gaming enthusiasts the power to break the 16GB barrier."
Features
- 8GB Modules
- Each twin module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 10-10-10-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 10-10-10-27 values at 1600MHz, 1.50V
- 16384 Megabytes of DDR3 memory
- Two matched 8GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge/Ivybridge compatible
Only £89.99 inc VAT.
ORDER NOW
