Razer Destructor 2 Expert Mouse Mat - Battlefield 4 Edition @ £22.99 inc VAT
Battlefield 4™ Collector's Edition
Gain the competitive edge with the same gaming gear used by pro-gamers in the biggest modern combat shooter yet from DICE and EA, only with the Razer Battlefield 4™ Collector's Edition Peripherals and Gear. All these weapons are designed to work perfectly on their own, but when armed together, you become a highly effective soldier honed for victory.
Only in Battlefield™ can you experience this amazing level of all out war.
Only with Razer can you get the competitive edge to obliterate all who oppose you.
Battlefield 4™ Razer Destructor 2 - Hard Mouse Mat for Gaming
Optimized Surface Coating
Validated by the world's top pro-gamers, the Razer Destructor 2 features a new highly reactive surface coating. Tiny silver flakes embedded over the surface heighten its reflective quality to deliver rapid in-game responsiveness.
Textured Finish
The Razer Destructor 2's surface is micro-textured to provide the perfect balance between control and speed. Get the right level of resistance to your mouse movement to land pinpoint accurate shots, while moving the mouse as freely as you need across the mat.
Non-Slip Rubber Base
The Razer Destructor 2 is designed with a non-slip rubber base that keeps the mat fixed to one spot no matter how hard you swipe. Nothing can throw you off your game.
TECH SPECS
Optimized surface coating for highly responsive tracking
Micro-textured finish for balanced gameplay
Non-slip rubber base
Product dimensions:
Width: 255 mm / 10.04"
Length: 355 mm / 13.98"
Height: 2.2 mm / 0.09"
Approximate Weight: 166 g / 0.37 lbs
Only £22.99 inc VAT.
ORDER NOW
______
Mionix Sargas 450 SK Performance Cloth Gaming Surface @ £17.99 inc VAT
The Sargas 450 SK is made of a durable microfiber cloth material with slightly more friction than coated mousepads. The special microfiber surface counteracts data loss and improves the sensor tracking performance. The Sargas 450 SK was built with our in-house S.Q.A.T. technology which tests the data loss of the surface, many months of testing has been carried out to ensure that this cloth pad has an extremely low data loss. The underside is made of a natural rubber offering a firm grip irrespective of the surface under the mousepad or extensive movements. The wide tracking area ensures for long sweeping movements without interruption.
Features:
- The official gaming mousepad of SK Gaming, as used by the SK Gaming team
- Improved tracking performance: Microfiber surface counteracts data loss and improves sensor tracking performance.
- Greater control: Decreased friction to improve the control over your every move.
- Non slip grip: Firm grip irrespective of the surface under the mousepad
- Extra wide tracking area: For sweeping movements without interruption.
- 2 years manufacturer warranty
Specification:
- Material: Durable, smooth and flexible microfiber
- Surface: Uncoated / semi rigid
- Dimensions: 450mm x 400mm
- Thickness: 4mm
- Underside: Natural rubber
- Compatibility: Optical and laser
Only £17.99 inc VAT.
ORDER NOW
Textured Finish
TECH SPECS
Product dimensions:
ORDER NOW
______
Features:
Specification:
- Thickness: 4mm
ORDER NOW
