Today we have a useful piece of equipment a external USB Bluray writer. Being USB you do not have to hard mount the equipment into your rig and you can take the drive anywhere and watch BluRay movies on the go!
We also have more graphics card goodness giving a better price and more performance. Be prepared for the latest and greatest games and high quality is calling your name!!
Storage Options 6x External Slimline USB Blu-Ray Writer - Black/White @ £99.98 inc VAT
Storage Options presents this slim external Blu-ray writer drive which features support for all CD, DVD and Blu-ray formats, including BD-RE and BD-RE Dual Layer. Powered by Panasonic optical drive, this Blu-ray writer is capable of burning CDs at up to 24x, DVDs up to 8x and Blu-rays up to 6x. With support for ReWriteable (RE) and dual layer (DL) Blu-ray formats, this drive provides versatile recording options for all situations.
- Portable, slim and lightweight design ideal for travelling, business and students
- USB powered – no need for power adapters and cables
- Power saving function
- Fast USB connection – ideal for laptops, notebooks or netbooks
- SuperWrite technology supports all CD, DVD formats, including DVD-RAM
- Includes free CDBurnerXP software for simple burning of CDs and DVDs
Only £99.98 inc VAT.
ORDER NOW
MSI GeForce GTX 560Ti OC Twin FrozR II 1024MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £174.98 inc VAT
Key Features
Twin Frozr II Thermal Design 20 Degrees Celsuis Cooler!!
- Dual 8CM PWM Fans for 50% more air alow can cool down GPU/Memory/Power Module at once.
- Four heat pipes with SuperPipe Technology
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.
7+1 Phase PWM Design
- Higher current to GPU Powerv
- Higher overclocking capability
- Better stability in peak load
Military Class Components
- Hi-C Cap provides more precise GPU voltage.
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement.
- All Solid CAP for longer lifespan.
Specifications
- Dual 8cm PWM Fans for 50% more airflow.
- Superpipe technology and nickel-plated copper base for better dissipation
- 20c cooler than reference design
- Military Class II Components
- Core Clock: 880MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4200MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1760MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Supplied FREE with Batman: Arkham City FULL PC game (subject to availability. Game is launched on 21/10/2011 downloads previous to this date will be declined)
Only £174.98 inc VAT.
ORDER NOW
ORDER NOW
Key Features
Specifications
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
ORDER NOW
