**Today Only 04/10/2012** Aerocool V12XT BlueLine Edition Fan & Qpad MK-85 LED Pro Backlit Mechanica
22 Aug 2010
Today only dealios!
Aerocool V12XT BlueLine Edition Fan - 120mm @ £4.99 inc VAT
Special designed 120 x 120 x 25 mm transparent Black fan for improved air flow !!
Combination of Small fan hub and Large fan blades pumps out the maximum air flow and mininum amount of noise. Quad Blue LEDs, 3 + 4 pin connectors and Anti-vibration screws to minimize the fan vibration.
- Dimension: 120mmx120mmx25mm
- Rated Voltage: 12 V
- Operating Voltage: DC9-13.8V
- Air Flow: 30 CFM(max)
- Static Pressure: 0.3mm-H2O
- Input Current: 0.3A (max)
- Input Power: 3.6W
- Speed: 1000 RPM±10%
- Noise: 17.6 dBA
- Operating Temperature: -10 degrees centigrade to +60 degrees centigrade
- Bearing: Sleeve
Only £4.99 inc VAT.
ORDER NOW
Qpad MK-85 LED Pro Backlit Mechanical Gaming Keyboard - UK Layout @ £95.99 inc VAT
Unlike your average keyboard, that functions through rubber domes, forcing you to press each key all the way down in order for the stroke to register, the MK-85 feature true mechanical switches with unmatched accuracy and feel. No more pressing with full-force in order to activate the keys.The QPAD keyboard will respond to your every stroke in an instant.
Other boards normally have a short life span and wear out quickly, resulting in unresponsiveness, delays and a dull, clunky feel to the keys. The key switches on MK-85 are built to last 50 million strokes, and the QPAD mechanical key technology provides distinct feedback and puts you in absolute control. The travel distance of the keys is set to 4mm with an actuation point at 2mm.
For gamers, it’s all about the feel and functionallity and that is where the QPAD MK-85 truly shines. With a full size keyboard layout in 3 sections, gaming profiles, macro recording, mechanical key switches, media keys and full N-Key roll over via USB, it’s the perfect gaming keyboard. Nuff said...
- Key switch: Cherry MX mechanical switch technology
- Cherry Red Switches
- N Key Roll over: Full N-Key roll over via USB
- Key strokes: 50 Million
- Lighting: Individual LED backlight on every key for enhanced visuals
- Lighting features: Four levels of brigthness allow you to locate keys easily
- Connectors: Gold plated USB connectors for extremly low latency
- Media keys: Media keys for volume control, play, pause and skip tracks
- USB Hub: Two high speed USB 2.0 ports
- Audio ports: 3.5mm headphone-out and microphone-in jacks
- Cable: 1.8 meter braided cable
- Extras: 4 extra orange key caps and key cap puller
- Dimensions: Keyboard: 44,8 x 14,9 x 3,5 cm (17,6 x 5,8 x 1,37 inch)
- Wrist pad: 44,8 x 6,6 x 1,7 cm (17,6 x 2,48 x 0,66 inch)
- Weight: 1.27 Kg (2.8 LBS)
- Warranty: 2 year
- Software: Customizable profiles, programmable keys and macro recording
- Supports: Windows XP, Vista, 7
Only £95.99 inc VAT.
ORDER NOW
I bought the keyboard last week at £104.99, its a fantastic product, a bit gutted its dropped a tenner in a week, but hey ho. I was hesitant before spending that kind of money on a keyboard but it is superb and Im really glad I bought it.
Would people reccomend going for one of the backlit qpads?
The MK-50 is more like how much I want to spend, does it look sad without the lights or will I most likely not care?
Can't believe its £20 extra just for lights tbh.
Just seen a irl pic of the mk 50, I think I'll get it now. Just need to justify it somehow.
Just received the keyboard this morning, great as usual from OcUK !! (Finally got some Haribo this time :D)
just getting used the the the switches and the noise they make. It defiantly feels different from my old rubber-dome keyboard.
